CC306 Cam only dyno
Old Apr 21, 2010 | 08:31 PM
  #41
SS RRR's Avatar
Village Troll
Originally Posted by blackz93
How is it THAT heavy?
A near 4000lb f-body is very heavy.
Old Apr 21, 2010 | 08:45 PM
  #42
06blackGTO's Avatar
Originally Posted by 86formula
i went 12.5 @ 110 with a stock cam... thats not saying much for the 306 lol
It's all on the location. Your car wouldn't run a 12.5 at 110mph. on stock cam here in KC, unless you had some other stuff going on with it, and it was on a serious diet.
Old Apr 21, 2010 | 09:08 PM
  #43
Z28Camaro30Ann's Avatar
On top of that, he has a 355 as well! The ONLY difference is his is bored .030 so its actually a 355...mine is bored .040 so mine is a 357! He has similar heads, LT Headers, and a bigger cam in the cc306! AND he is tuned.
I have a 357, similar heads, LT Headers, and a smaller cam with my custom grind but I am still not properly tuned. As Hammer said...My AFR is nowhere near what its supposed to be.......
Old Apr 21, 2010 | 10:14 PM
  #44
themadspoon's Avatar
Originally Posted by Wicked94Z
!!! get that bitch on a diet dude, and get some gear in that thing!
There is nothing in it I want to lose lol.
When you do it with a DA of 3000+ feet in a near 4000lb car with a 2+ second 60' let me know.
Old Apr 21, 2010 | 10:29 PM
  #45
How is yours near 4000????? Mine with me in it weighs 3710!
Old Apr 21, 2010 | 10:36 PM
  #46
myltwon's Avatar
Originally Posted by zlicious94
I run the same time with a stock cam lol!
you also trap 4mph less and probably weigh less as well
track elevation is also a factor to consider
Old Apr 21, 2010 | 10:38 PM
  #47
myltwon's Avatar
Originally Posted by Z28Camaro30Ann
I raced a 96 LT1 with a cc306 cam...I am running a considerably smaller cam than that. We have similar mods (Ported Heads, 1,6RRs, LT Headers, 355's, etc) on our cars so by all rights if you go by "dyno numbers" he should have beat me. He will put more down on a dyno than me most likely...HOWEVER...from a dig on street tires I put a length and a half on him. Not saying he is slow or anything, but my cam uses my DCR differently. I dont bleed compression and I have ALOT of accelleration from top to bottom. I shift at 6400.
racing on the street isn't the best comparison waaaay too many factors
-traction
-driver ability
-reaction
-etc.
Old Apr 21, 2010 | 10:50 PM
  #48
Lol idk It has everything in it except spare tire, The wheels are heavy and I Think it was at about 1/2 tank when scaled.
Old Apr 21, 2010 | 10:51 PM
  #49
I agree, but I was pulling on him more top end than bottom. Even from a 40mph roll I pulled on him fairly hard
  #50
mine was 3/4 tank lol, and I had stock ZR1 17x9.5 rims on mine with street tires and no spare
Old Apr 21, 2010 | 10:55 PM
  #51
Bersaglieri's Avatar
The crappy CC306 has been to the mid 11's cam only.
-Dustin-
Old Apr 21, 2010 | 11:05 PM
  #52
CamaroRacing12's Avatar
hahahah classic.
yea i have been 12.42 @ 107mph and have trapped 109mph stock cam also, i've also gone in the 7.8x's in the 1/8th...
but like he said my raceweight was 3250lbs and my DA was right around 0 or in the negatives.... compared to his 4000lbs and 3000ft DA there is a big difference there
Old Apr 21, 2010 | 11:10 PM
  #53
Matts94Z28's Avatar
I made 330hp with that crappy ***'d cam. I also ran 7.6's first time out and will probably go .40's this coming weekend. Stock headed 355 with a few bolt ons
Old Apr 22, 2010 | 02:30 AM
  #54
Wicked94Z's Avatar
-Dustin-
where's clint, he's someone who has made the cc306 run very well in a 355.
Old Apr 22, 2010 | 02:37 AM
  #55
gregrob's Avatar
-Dustin-
So has the hotcam.
Old Apr 22, 2010 | 02:53 AM
  #56
Wicked94Z's Avatar
so has the stock cam...
Old Apr 22, 2010 | 03:58 AM
  #57
4K+Converter's Avatar
Where is the rest of the dyno sheet? Your power band hasn't even begun to trail off at 6000. Run it out to 6600+. With a peaky big cam, you need to keep it in its power band. Otherwise you'll get beat by cars who shouldn't beat you on paper.
I looked at the F-Body gear calculator and threw some data in and cross referenced it with the dyno sheet.
Shifting at 6000, the rebound into 2nd at 4000. The motor makes ~270 rwhp at 4000.
Shifting at 6600, the rebound into 2nd at 4400. The motor makes ~295 rwhp at 4400.
Shifting at 6800, the rebound into 2nd at 4600. The motor makes ~315 rwhp at 4600.
By winding it out higher, you get more average horsepower throughout your time in each gear. I made a quick spreadsheet to see what your average horse would be. As a former CC306 owner, I made an informed guess at what your power band looked like after 6000 rpm with stock heads.
4000 rpm through 6000 = ~325 average horsepower.
4600 rpm through 6800 = ~338 average horsepower.
I had a 4000 stall and a CC306 with LE2 heads and it needed more converter. Re-stalled it for 5000, and it ran like a raped ape.
Edit: IMO, there are a lot better cam choices out now than when I got the CC306 many years back. Bigger is not always best. Grab a custom cam for the rpm you want to run.
Old Apr 22, 2010 | 05:08 AM
  #58
Redfire 03's Avatar
This car had over 180k miles at the time of this video, stock bottom/stock heads CC306/Full Bolt-on and made just a tad under 370whp. FWIW, PCMForLess dyno'd a 306-cam'd 92 Vette that did 370 - stock heads of course.
http://www.youtube.com/watch?v=D7oldCq96Os
Yes the CC306 is old technology but I still can't think of one single LT1 cam out there that will put down the numbers the 306 will on the stockers. Yes the low end is sluggish but the monster top side more than makes up for it. With some gears and the right stall you can really run some impressive times with this cam.
Old Apr 22, 2010 | 06:07 PM
  #59
zigroid's Avatar
you people dissing the cc306 and big cams in general are a bunch of morons.
throwing **** out like "a proper combo" well maybe a big cam is part of the "proper combo"?
I had a 242/250 with stock heads in my old '94 formula and it just flat out hauled *** from the moment I touched the gas pedal. it was part of a "proper combo" though.
Old Apr 22, 2010 | 06:35 PM
  #60
hsyr's Avatar
So what magical cam would do sooo much better than the 306 and your stock cam?
