CC306 Cam only dyno
Old Apr 18, 2010 | 12:09 PM
themadspoon's Avatar
Default CC306 Cam only dyno
Car has 150,000 miles mods are:
Moroso CAI
Pacesetter Longtubes
CC306
1.6RR
Ported Stock TB
Tune By Muscle Car Specialties
Old Apr 18, 2010 | 12:12 PM
RamAir95TA's Avatar
This is a perfect example of why you don't put a huge cam on stock heads. Power peaks at 5500 RPM.
Nice numbers anyway.
Old Apr 18, 2010 | 12:47 PM
95Prplppletrz28's Avatar
it actually looks like the last little ripple of incline comes at around 6k, id shift around 6400rpms and do work...Nice numbers
Old Apr 18, 2010 | 12:48 PM
draggin97s10's Avatar
the torque curve isnt bad at all but wow the hp curve is ugly. nice peak
Old Apr 18, 2010 | 12:49 PM
how much did the charge for dyno tune. im in kc area.
Old Apr 18, 2010 | 01:12 PM
96lt1m6's Avatar
[QUOTE=RamAir95TA;13204455]This is a perfect example of why you don't put a huge cam on stock heads. Power peaks at 5500 RPM.
Come on Joe, jogging 20 miles then breathing from a straw is common practice.....LOL
Numbers are not bad at all but do have room to grow
Old Apr 18, 2010 | 04:55 PM
flyinZ's Avatar
For a tired motor, and a few bolt-on's..Not too bad.
Old Apr 18, 2010 | 05:41 PM
stevo9389's Avatar
thats about where i was on a stock 140k motor with a GM847 (sort of similar specs) before it let go a few years ago. the only difference in mods was that i still had 1.5rr
Old Apr 18, 2010 | 06:15 PM
hsyr's Avatar
I really can't see why people knock this cam. I mean, which smaller cam out there makes more power? I don't care about having a ton of HP at 3500rpm either, I mean do you race at that rpm or 5500+?
Nice numbers!
Old Apr 18, 2010 | 07:22 PM
zlicious94's Avatar
I run the same time with a stock cam lol!
Old Apr 18, 2010 | 09:57 PM
Nice numbers!
so your trying to say the your motor is immeditaly at 5500. thats absolutley retarded. you want power all the time thats what makes a car fast.
Old Apr 18, 2010 | 09:58 PM
prime example of my above post
Old Apr 18, 2010 | 10:09 PM
SS#1230's Avatar
hold on....350 at the wheels??? am i missing something? thats a lot of HP for a 150K LT1 with those mods.
wrong?
Old Apr 18, 2010 | 10:33 PM
no deffinitly great peak numbers. Not saying that.
Old Apr 19, 2010 | 01:24 AM
happysem's Avatar
Your FQuick says 341rwhp/350rwtq and same 1/4 time.
I'm calling BS on you somewhere, are you running an LT4 cam, or just the RR's and springs?
Or is it a "stock cam" thats been re manufactured or something?
Also, you've got some weight pulled out, he's probably full weight.
Old Apr 19, 2010 | 01:57 AM
Bersaglieri's Avatar
Imagine if you had full bolt on's. E-WP and true duals, perhaps a underdrive pulley or 58mm TB, that thing could crack 360-370rwhp on stock heads. I don't care who you are, if your 150k LT1 makes over 360rwhp at the wheels cam-only it's damn good. Everyone rags on that ole CC306 and yes the design is old and it bleeds off compression, but the bastage puts down numbers time and time again.
Fast cars arent the one's who make good power everywhere, ask fast guys how many seconds of the quarter mile they spend below 5000rpm. The whole point of a high stall converter or clutch drop off the line is to put you into that higher RPM band. Next time you go to the track try to use your whole powerband and creep out of the hole at 1000rpm and see how that works for ya. Soak up every ounce of TQ below you can below 3500rpm. I not saying you dont need it, I'm just saying you want to make power at the RPM you spend the most time. I think my car spends 1.0 second below 4500rpm.
-Dustin-
Old Apr 19, 2010 | 09:54 AM
thats not what i ment by fast car. but ill try that next time im at the track. but i have ran a 13.91 in a completely stock car minus cut out. it had 187xxx.
Old Apr 19, 2010 | 10:25 AM
CamaroRacing12's Avatar
great numbers man. and a great curve.
Old Apr 19, 2010 | 01:11 PM
My car weighs 3920 with me in it, it is full weight! lol. When it went 13.0 @ 111 it was on bald street tires and 60' footed 2.2
Old Apr 19, 2010 | 02:58 PM
hsyr's Avatar
If I'm going to race someone from a roll i'll drop it a gear to get the rpms high up there and if from a stop I'll launch so my rpms are up there. I don't know many who like to race at a low rpm haha that my friend is retarded!
