#2 plug removal
Old Apr 21, 2010 | 08:32 PM
Hellbentz's Avatar
going to be doing my plugs and wires in about a week, but im removing the stock manifolds and putting on full exhaust at the same time.
Old Apr 22, 2010 | 07:20 PM
MasterTomos's Avatar
^ that will make it worlds easier...
Old Apr 22, 2010 | 09:36 PM
OnA Fan's Avatar
You may want to do the motor mounts too while the exhaust is out.
Old Apr 22, 2010 | 10:35 PM
great421's Avatar
OK, this is how I did my #2 plug (from the top with a stock exhaust):
1. Remove Alternator (A given!)
2. Put shorty / SLP socket on plug (by feel)
3. Put larger 3/8 drive socket over hex head on outside of shorty / SLP socket (by feel as well)
4. Using a 3/8 drive air ratchet, remove plug, SLP socket, and larger socket as assembly.
Give that method a try...
Having said that, removing the entire air pump and tube system helped the second time I replaced my plugs.
