sts?
and 400/408@7psi with meth. That was with a sts kit w/ t67 upgraded turbo. Anything over 5psi I would recommend running a intercooler or meth. U will be okay on a stock lt1 engine with 7psi -with meth or intercooler. Just make sure u have the fuel upgrades, good tune and dont run more then 7psi to be on the safe side like I did. Never had any problems with mine
First, boost is boost. 7 pounds on a Powerdyne has the same horsepower as 7 pounds on an STS.
Second, 400 rwhp is 400 rwhp. If you race a car of equivalent weight and power, you will have an equal outcome.
Third, it is widely known that manuals love a supercharger, autos love a turbo. After I wrapped the exhaust, I have virtually no turbo lag at all. And I moved my turbo up where the only way you can see it is to be below the bumper.
My car was a ton of fun with a completely stock engine and 400 STS rwhp. I really liked the way it ran when not in boost; as smooth as stock, because it was stock.
Boost is pressure, airflow is volume. They are two very different things.
You could run a tiny turbo way out of its map and make xxx psi boost and be doing nothing but flowing hot air into the engine. By the same token you can put a larger more efficient charger on and run it at the bottom of its map where its much more efficient than the smaller charger, and flow more air and make more power, at a lower psi...
What do you think would happen if you were to go from a stock unported head at 7lbs of boost to a fully ported 235cc head and not change anything else.
What would happen to boost with the exact same turbo setup.
What would happen to hp?
I don't need lectures on turbos, I work in the industry. Please save such comments for newbies that deserve it.
Back to your regularly scheduled progamming.
you have a lot to learn
start here
http://www.gmhightechperformance.com...est/index.html
