What Is This Plug Telling Me
Old Apr 24, 2010 | 07:45 PM
dubga's Avatar
Default What Is This Plug Telling Me
While I am installing headers, I checked my plugs on the driver side. Number 5 (second from the rear driver side, that's 5 right?) is brown on the insulator. The others are still fairly white. Plugs have only 2-3000 miles and are NGK TR55IX Iridium. Gap is .054 and using MSD wires installed at the same time as the plugs. Pic below.
Old Apr 24, 2010 | 08:57 PM
Bowtie Boy's Avatar
The darker one may be running too cold, but you think you would have more then 1 like that. Could have been seated wrong. I have seen alot worse.
Old Apr 24, 2010 | 10:54 PM
Nastyc4's Avatar
Have any of your wires ever been found loose or not fully connected? Also, take that injector and switch it with the next one. then check the plugs after a few hundred miles.
Old Apr 24, 2010 | 11:03 PM
suicidal racing's Avatar
its a rich condition for sure...is that wire burned at all or is that injecter leaking..these are probley what would be causing this
Old Apr 25, 2010 | 12:48 AM
dubga's Avatar
The wire is not burned. It didn't feel loose when I pulled it off the plug. I can check the other end. I was wondering about the leaky injector. Good idea about switching it around and see if the problem follows the injector.
Old Apr 25, 2010 | 03:14 AM
Nastyc4's Avatar
Try that and see if there's changes in the plug. If it's a consistent issue it can possibly be rings which can be checked by a compression test or even worn valve guides which is allowing some oil through. Have any pics from the top view? Would be nice to see the electrode or the flat surface where the threads begin
Old Apr 25, 2010 | 04:43 AM
i also agree with doing that even though the plug looks only carbon fouled and not oil fouled out.what i do notice is the timing mark on the strap..its not really there which means shes not really fireing of like she should be if you ask me to put the heat/timing mark on the plug.but its hard to see on the bad plug.
to bowtie boy he had it seated right because if not you would beable to see it right at the tip an start of the threads on the plugs..
Old Apr 25, 2010 | 04:54 AM
gregrob's Avatar
So you can read timing by looking at the SIDE of the strap now huh?...
And you can see the timing marks, on the plugs, in the pic above?
Old Apr 25, 2010 | 06:07 AM
yes you can see the timing mark on the side of the plug.you can see on the good plug where the timing is on the ground strap from the side and from the front..i clearly said you cant really see on the other because of the bad pic but it looks like its not lighting off right.so there for hes not getting the proper heat to show the mark an could be the reason for the rich condition or 1 of them..
Old Apr 25, 2010 | 06:15 AM
FASTFATBOY's Avatar
Is it using oil? Looks as though you may have low compression on that cylinder, the strap is "wet" and it aint with fuel.
We need a pic from the top please.
Old Apr 25, 2010 | 01:23 PM
dubga's Avatar
Car has never used oil that I could tell. Wetness may be where I wiped off some excess anti-seize and dragged it down there.
Old Apr 25, 2010 | 11:34 PM
blackz93's Avatar
Definitely.
Old Apr 26, 2010 | 12:18 AM
i say check for ignition problems or leaky injector still..its either not fireing off or its getting loaded from a leaky injector..
the lil oil blow by is normal on them
Old Apr 26, 2010 | 07:34 AM
dubga's Avatar
Soon as I wake up from this nightmare that is my header installation I will start checking for injector leaks.
Thanks for all the input. Will post back when I check the injectors.
Old Apr 26, 2010 | 07:44 AM
FASTFATBOY's Avatar
Gas injectors dont usually"overfuel", they will leak down when the car is off.
Is the car hard to start?
Does it miss or rough idle when it does start?
If not, its probably not an injector.
I would do a leakdown on that cylinder.
Old Apr 26, 2010 | 08:36 AM
dubga's Avatar
No hard starts, rough idles, or misfires. At one time I was having trouble with occasional hard starts, but a new fpr fixed that. That was replaced before I got these plugs.
