xfi 292
Old Apr 26, 2010 | 05:41 PM
  #61
big_bird_93's Avatar
Lol i thought this was a thread about a comp xfi cam. Actually about Hp to Et comparison. I must be lost.
Old Apr 26, 2010 | 05:43 PM
  #62
buzz12586's Avatar
Lol my bad. I just couldn't believe what a ridiculous statement he made.
Old Apr 26, 2010 | 05:45 PM
  #63
gregrob's Avatar
Who here thinks that Boosted LT1 is Boostedpower's brother.
*raises hand*
Old Apr 26, 2010 | 05:49 PM
  #64
speed_demon24's Avatar
I prefer to shift around 5500 so I don't fall off the torque curve.
Old Apr 26, 2010 | 06:06 PM
  #65
jay97lt1's Avatar
I just run data master on my car and accoerdind to datamasters built in tach my autometer is 800 rpm higher then datamaster.
Old Apr 26, 2010 | 06:08 PM
  #66
gregrob's Avatar
LMFAO. So you where shifting at 5200 with the XFI 292.
Win.
/thread
Old Apr 26, 2010 | 06:27 PM
  #67
jay97lt1's Avatar
I guess so
Old Apr 26, 2010 | 06:29 PM
  #68
gregrob's Avatar
Ok, I'll quit being a dick for a second and reiterate what others have already told you.
Go to a test and tune night and do a little "testing and tuning".
First, shift where you did before and write down your trap speed.
Then shift at 6200 and write it down
then 6400
then 6600
then 6800
then 7000
and so on. If you have datamaster record the runs with it and see where you are actually shifting.
What is your rev limiter set at?
Old Apr 26, 2010 | 06:30 PM
  #69
gregrob's Avatar
And by those RPMs I dont mean what your tach reads, I mean ACTUAL rpms.
I would suspect you'll find the ideal sweet spot between 6600 and 6800.
Old Apr 26, 2010 | 06:35 PM
  #70
jay97lt1's Avatar
Iam in the process of converting to OBD1 so when I get my tune dailed in I will go back but first Iam replacing the opti thats never been replaced I have a exhaust leak where my headers meet my ORY thats got to be fixed.
Old Apr 26, 2010 | 06:39 PM
  #71
Wicked94Z's Avatar
Originally Posted by Wicked94Z
i want to hear lots of specs...
Intake runner CCs
Valve size
Valve springs
Installed height
Preload
Deck height
Head gasket thickness
Dyno sheet
i'm assuming you don't know then...
Old Apr 26, 2010 | 06:43 PM
  #72
jay97lt1's Avatar
I said before I got the heads used and I dont know
Old Apr 26, 2010 | 06:46 PM
  #73
Wicked94Z's Avatar
your whole build is a fail. take a valvespring off and test it. find what your installed height is, what your open/closed pressures are, and what coil bind is.
Old Apr 26, 2010 | 07:00 PM
  #74
infinitebird's Avatar
Ok so you don't know anything about the heads. Then, as said they are probably junk.
Between that and your lack of RPM, just those two issues are all it would take to see the subpar results you are seeing.
Old Apr 26, 2010 | 07:09 PM
  #75
boosted LT1's Avatar
*raises hand*
When you post anything that takes more than 30 seconds to write AND is correct for a change I will care what you thiink.
I carefully answered a thread and a person took 30 seconds to say it is wrong. I didn't handle it well true but it is easy to say something is wrong and twist your own words...
Let me put it in a way that even you will get..
Originally Posted by buzz12586
Well I can prove you wrong with one car. My car dynoed 330rwhp and has run 11.941 @ 112.98. All of the calculators on that site say that I need more horsepower in order to run that ET.
That means a 3400 pound car with 330 hp will go 11.941. I then say all people on here are far below what their can should be running!
Becuse a 3700 lb car will go the same et with 358 hp!
What person will believe that? No one that has any clue the larger and or looser the convertor the less reliable dyno numbers are!
There are MANY cars in the 10's dynoing 400 HP that is the DYNO's problem not the calculators!
If you don't see that you are beyond help!
Good luck
Resend the datamaster file it didn't arrive!
Old Apr 26, 2010 | 08:14 PM
  #76
He is dead wrong. Hey calculator hero, how bout you go actually DO something (ie race your car) instead of being an internet expert and you might be able to teach us something. Until then, STFU.
The only calculators that ate close ate the weight vs trap speed ones. Everyone knows the ET ones are a home because too many factors go into running a good et, with HP being only one.
A buddies car makes 960 HP and ran a mid 11 the only time it went to the track.
Bet that pisses your little calculator off.
PS it trapped 156 on that run...
First learn to read go to my garage look a my timeslip...
You should LEARN something about drag racing before posting pure BULLSHIT.
mid 11 and 156mph is a LAUGH makes NO sense calling you a moron insults morons!
Wow you know someone that has a car damn that is pitiful. To impress a girl I bet you point to your friends pants ha?
Do you realise how lame your statements are? You define ignorance and I suspect impotence.
Damn you are special AND only a MORON would say an 11 and 156 that shows you have NO clue about racing. Before getting my tune right and with only 16 psi I went 6.11 my car would coast to a 10! WHAT a MORON
Don't believe look at my garage and time slip (note the date and when it was post). BEYOND funny NOW NEVER say a word near me you must follow your own advice and STFU you KNOW NOTHING and YOU PROVED it!
Old Apr 26, 2010 | 08:27 PM
  #77
gregrob's Avatar
Ooh I think I struck a nerve. Keep hurling toothless redneck insults, it suits you. I proved I know the difference between a reality and an internet calculator. You're wrong, you're red in the face, your ego had been damaged and instead of addressing the FACTS you result to personal attacks.
Keep them coming, they are quite amusing.
Old Apr 26, 2010 | 09:03 PM
  #78
Thanks for the signature I didn't want to use your other notables since I wasn't part of the threads. This one is sooo special and ALL MINE!.
You said the only accurate calculators use MPH READ this thread you will see mine uses MPH. Don't you get ANYTHING right?
Your mid 11 at 156 was a total lie that is obvious to ALL. And for my gong to the track Sonny I have been there since before you were born. Didn't you see my garage there are picture even you should be able to read a timeslip but then again I forgot who this is...
Thanks again for the laugh I thought your welding rods was unbeatable but you did it! A dubious notoriety.
PLEASE keep posting you are the best proof of your inabilities.
Old Apr 26, 2010 | 09:07 PM
  #79
gregrob's Avatar
Lol..
Old Apr 26, 2010 | 11:06 PM
  #80
gregrob's Avatar
This dumb redneck mother ****** wont stop sending me PM's. Lol it's a great laugh. I'm going to buy some popcorn as we speak.
