xfi 292
Old Apr 27, 2010 | 08:08 PM
  #101
wrd1972's Avatar
Originally Posted by ******
yes your tune need to be right...but if Jesus came to your door to tune it and the motor had issues....he would not be able to get it right. you need to address the mechanical issues first than have the tune looked in to.
as noted that cam is not ideal and when set up correctly requires high (7k) RPMs to see max potential.
another cam choice with correct springs set up properly AND a good tune wiould be the best situation.
as mentioned keeping what you have will also work...just need to get valve train up to it and the tune if that in fact needs attention.
Are you kidding.
Jesus would say "Thou shalt get an LSx engine and sin no more".
Old Apr 28, 2010 | 08:54 AM
  #102
jay97lt1's Avatar
No one has anything to say now I posted my dyno sheet
Old Apr 28, 2010 | 09:29 AM
  #103
wrd1972's Avatar
It appears to me to have a slightly narrow torque curve probably due to being clipped up top. Also it looks like the dyno operator got off the gas right at 6K RPM and its hard to really tell if there is a float problem. One thing is certain, something is bad wrong here for a 242/248 cam to peak at 6K RPM as shown on the graph.
Old Apr 28, 2010 | 07:51 PM
  #104
jay97lt1's Avatar
What do this dyno sheets tell you
Old Apr 29, 2010 | 11:22 AM
  #105
Low N Slow's Avatar
The second sheet looks like it's running way lean, you need to work on the tune.
Old Apr 29, 2010 | 01:16 PM
  #106
vtec's Avatar
Resident Racing Jerk
i am running an off the shelf comp "old school" cam that is smaller than this one.... it puts down around 425rwhp thru a th400/9"rear/28" slicks and peaks 6500ish.
350cid with ported factory heads and single plane.
Old May 10, 2010 | 06:20 PM
  #107
6801's Avatar
just gotr running this cam sounds like a baby
Old May 10, 2010 | 07:36 PM
  #108
96capricemgr's Avatar
That is because the LSA is huge to compensate for people making the poor choice of going too big on the duration.
Old May 10, 2010 | 08:54 PM
  #109
Wicked94Z's Avatar
looks like valve float combined with less than good heads, and crappy tune.
Old May 10, 2010 | 09:58 PM
  #110
boosted LT1's Avatar
He has Tunercat on the way and I doubt anyone can develop a tune as far off as his dyno pull shows.
When the AFR is that low I don't see how you can tell anything about the setup. The chart shows the motor was extremely lean, and I am amazed it made any power.
When the AFR is in range the motor will be totally different. Not ideal but he will be respectable and he then can decide where he is willing to take the setup.
