Catch Can?
Old Apr 26, 2010 | 08:11 AM
nirvana1221's Avatar
Default Catch Can?
I was just wondering what catch can you guys are using and if you give let me know were you ordered it from thx
Old Apr 26, 2010 | 09:10 AM
boosted LT1's Avatar
Why do you need a catch can are you boosted?
On my rearmount LT1 I don't a puke can one since it is low power and boost is ~14 psi.
I have one that was fabbed for my drag car. The drag car also needed tall valve covers and I may use an evacuation system from the exhaust. Short term I will try adding a second puke line. The taller valve covers are easier to work with since getting fittings on the stock valve covers is a bit of a problem.
I haven't had any problems <16 psi
Good luck
Old Apr 26, 2010 | 10:58 AM
Nasty N8's Avatar
We offer a breather style catch can to vent your covers to. Billet and fabbed styles.
Old Apr 26, 2010 | 03:26 PM
StealthFormula's Avatar
My buddy has made a few using air compressor filters. If you go to Home Depot/Lowes etc. you can buy one of those filters along with fittings for ~$30. Then go ahead and buy a couple feet of the correct diameter fuel hose and your good to. Here's what they look like, the same size as your typical catch can:
