LS1 Brakes...
Old Apr 26, 2010 | 03:44 PM
Z28Camaro30Ann's Avatar
Default LS1 Brakes...
Quick question.....how do I know if I already have LS1 Brakes on the front of my car or not?? I did not install them, but I dont know if the previous owner did or not...How would I find out?
Old Apr 26, 2010 | 03:48 PM
RamAir95TA's Avatar
LS1 brakes use twin-piston calipers. Should be easy enough to spot.
Old Apr 26, 2010 | 04:08 PM
96lt1m6's Avatar
calipers are much different in appearence.
rotors are smaller on the Lt1
Old Apr 26, 2010 | 04:12 PM
I have no idea how to tell the difference or anything...I know almost nothing about brakes to be honest. I know what a twin-piston caliper is, but how do I tell if they are twin-piston or not? Mine are powdercoated red with a "CAMARO SS" decal on the side of it. My fronts look NOTHING like my rears and I KNOW my rears are stock.
Sorry for the ignorance, I am trying to educate myself before I even TRY to take on new rotors...wanna make sure I get the right stuff.
Old Apr 26, 2010 | 05:13 PM
GREGG 97Z's Avatar
Ls1 calipers are aluminum, lt1's are steel. Ls1 rotors are 12" dia, lt1's are around 10.5".
Old Apr 26, 2010 | 06:09 PM
gregrob's Avatar
Twin pistons, mean they have, imagine this.
TWIN
PISTONS
Old Apr 26, 2010 | 06:18 PM
infinitebird's Avatar
A twin piston caliper looks like the right one, single looks like the left.
Notice which feature of the caliper is doubled.
Old Apr 26, 2010 | 08:23 PM
thanks! i guess i already have ls1 fronts! works for me lol! good thing i didnt but the slotted/drilled lt1 rotors haha!
Old Apr 28, 2010 | 10:13 AM
Disregard that, I still have LT1 brakes! I went and checked last night!
What EXACTLY do I need for a front conversion??
Old Apr 28, 2010 | 10:20 AM
moehorsepower's Avatar
You just need to go to your local wrecking yard and get the complete spindle off of an LS1 car, Spindle, calipers and rotor...Once you install these you will have to get an alignment done...
Old Apr 28, 2010 | 10:27 AM
Cool, I have someone selling me everything I just wanted to make sure I have it all covered. Thanks!
Old Apr 28, 2010 | 01:49 PM
also keep in mind that the ls1 lines are typically too short. you can either stretch the lt1 lines (or bend out the hard line) or get some new longer lines.
Old Apr 28, 2010 | 02:11 PM
Badazz 97 TA's Avatar
Calipers, rotors, spindles, new cotter pins, longer brake line. I bought the J&M LT1 style stainless steel lines for mine.
just for more referance for the future......
The stock brake lines compared to the J&M
The difference between the spindles. Left is the LT1, Right is the LS1
Differences In the Calipers. Left is LS1 right is LT1.
All the Ls1 stuff. pretty straight forward swap
Old Apr 28, 2010 | 03:50 PM
I knew I needed longer lines. Also I need some rear brakes as well because the deal for my LS1 rears fell through
Old Apr 28, 2010 | 04:05 PM
the ls1 rears are a total PITA compared to the front.
Old Apr 28, 2010 | 04:17 PM
wrd1972's Avatar
I will add:
LT1 = 10" rotors
LS1 = 12" rotors
Old Apr 28, 2010 | 04:59 PM
I am not too worried about the rears being a PITA. I am building an entire 8.8 rear end and gonna install the LS1 rears on that when i do the rear swap.
I am losing my ABS thanks to this 8.8 rear end so I dont have to worry about that either.
Old Apr 28, 2010 | 06:13 PM
Originally Posted by wrd1972
I will add:
LT1 = 10" rotors
LS1 = 12" rotors
no they are not 2 inches bigger. There about 1in bigger. heres a picture.
on the bottom is an Ls1 rotor. Top is the Lt1.
10.94 Lt1
11.92 LS1
Old Apr 28, 2010 | 08:55 PM
wrd1972's Avatar
Okay I stand corrected.
