waterpump
Old Apr 30, 2010 | 09:43 AM
CAMARO51190's Avatar
Default waterpump
need a new pump. how would u go about installing it?
Old Apr 30, 2010 | 10:17 AM
Drew24's Avatar
http://shbox.com/ci/water_pump.jpg here is a diagram and make sure you bleed the system after doing it. Courtesy of shbox.
Old Apr 30, 2010 | 10:32 AM
RamAir95TA's Avatar
Most importantly, make sure you protect your optispark the best you can from leaking coolant when you remove the pump from the block.
Old Apr 30, 2010 | 11:24 AM
Drew24's Avatar
While you got it out you might just want to do the thermostat as well and protect the opti like stated above. Make sure you seal it up good with permetex so it doesnt leak. Take your time and it will go smoothly
Old Apr 30, 2010 | 03:55 PM
suicidal racing's Avatar
yep and its a good time to do the sealing trick with rtv to your opti to...other then that its a straight forward thing to do the water pump
Old Apr 30, 2010 | 04:01 PM
RamAir95TA's Avatar
Not sure exactly what you're talking about, but the thermostat housing requires no RTV. Neither does the pump gaskets - I've always installed them dry.
