12.7s?
Old May 1, 2010 | 07:46 PM
LSWHO's Avatar
Default 12.7s?
So I'm thinking with my current modlist and a couple tweaks I can hit 12.7s Tell me if you think it's possible.
What I have:
OEM ramair intake
madz mail tune
LPP headers with open Y
3200 stall
3.42s
17" WS6 rims out back with 275s
16" swirl (93-94 oem rims) with ET streets
What I ran:
13.15@102.69
What I am going to change:
Restall to 4000
fix random misfire
skinnies up front
Think it's possible?
Old May 1, 2010 | 08:21 PM
TravisMcGill2000's Avatar
should be possible. Whats your da usally run. 102 mph seems low for your mods. Oh yea whats your raceweight.
Old May 1, 2010 | 08:26 PM
LSWHO's Avatar
DA was 1700' on the 13.1 run.
Full weight car... so far.
Old May 1, 2010 | 08:47 PM
what kind of 60fts you been pulling. Also whats your shift points set at.
Old May 1, 2010 | 08:51 PM
i usally mph arond 105 when i had your mods. Also start taking some weight out. Thats always cheap.
Old May 1, 2010 | 08:53 PM
LSWHO's Avatar
1.86 was on the 13.1 run. dead hooking.
Shift points are whatever Madtuner puts em at. 6k 1st I believe. Don't know about 2-3
Old May 1, 2010 | 08:54 PM
LSWHO's Avatar
12.9@105 is what sea level would be. I'm stuck in AZ. Hard to ever see 0' DA.
Old May 1, 2010 | 08:59 PM
ah ok. That 4k stall should diff. help 60ft out. You need get that thing down in the low 1.7s to high 1.6s.
Old May 1, 2010 | 09:00 PM
LSWHO's Avatar
That's my plan!
Old May 2, 2010 | 12:41 AM
CamaroRacing12's Avatar
theres only one way to find out man
Old May 2, 2010 | 03:17 AM
WhitePhoenix99's Avatar
Yep, if you were dead hooking then the 4k stall should really help. I was dead hooking to 1.9's with my 3k stall I need a new converter
Old May 2, 2010 | 03:48 AM
gregrob's Avatar
I dont see 12.7's with that mph. Hope you do but I would say a 12.9 would about knock it in the head. If you were trapping 106 - 108ish I could see 12.7's
But it's all in the 60. Get it to come out HARD and you could do it.
Old May 2, 2010 | 09:53 AM
Michigan Skip's Avatar
What I have:
OEM ramair intake
madz mail tune
3200 stall
3.42s
What I ran:
13.15@102.69
Restall to 4000
fix random misfire
skinnies up front
I'd say NO just changing what you mentioned. 4 tenths is a lot to gain with just a converter change and skinnies. Oh, and despite what people say about the 1.7-1.8 60' times, that doesn't always equate to a 12 sec timeslip.
Old May 2, 2010 | 09:59 AM
RamAir95TA's Avatar
I also will have to agree that you don't have the power to get 12.7s. You might be able to crack into the 12s no doubt, but 12.7 is a stretch.
Old May 2, 2010 | 10:01 AM
BUT, a conservative shot of giggle juice would definitely put you there..
Old May 2, 2010 | 11:30 AM
95Prplppletrz28's Avatar
what was that pass in the 1/8th like 8.4x@82 or so?
Old May 2, 2010 | 02:08 PM
Well he said his best 60' was a 1.86, so if he can manage a 1.66 or so I think it would be possible.
