LE2 Top end, do I need to refresh bottom end?
Old May 1, 2010 | 10:03 PM
Dadic 78's Avatar
Default LE2 Top end, do I need to refresh bottom end?
I was in touch with Lloyd Elliot, and I'm thinking I'll go with his LE2 setup for my '94 M6. Horsepower/Tq #'s are what I'm looking for, and the cost is in budget.
With my motor now, I've got 190,000 KM (roughly 120,000 miles) on it. Do I need to refresh the bottom end before I upgrade the top end? If so, what do I need to refresh?
This car will basically be a street ride, not see a lot of track time (if any).
Old May 1, 2010 | 10:15 PM
dangalla's Avatar
i would, you need to spin it pretty hight to get the power out of it
you dont need to, and people make it just fine - but your taking a big risk
i did a stock rebuild, stock crank - scat i beams - sealed power hyper pistons, mainly because i got the parts cheap and i spent my budget on bolt ons, top end, and valvetrain components
it all depends on your budget really, stock crank with forged 6 inch rods and forged pistons would be a great setup. and if you got the cash spring for the forged stroker crank
keep in mind that the little things really add up quick, and you need alot for a build like this, what is your total budget?
Old May 2, 2010 | 02:40 AM
Low N Slow's Avatar
If you are on a tight budget I would at least do rings, bearings and a new timing chain.
Old May 2, 2010 | 03:50 AM
gregrob's Avatar
I wouldn't do a damn thing to the bottom end
Old May 2, 2010 | 05:50 AM
86formula's Avatar
+1 just let her rip
Old May 2, 2010 | 08:57 AM
Badazz 97 TA's Avatar
If it aint broke, dont fix it!
Old May 2, 2010 | 09:15 AM
udlose99ta's Avatar
If you have had the car a while or know how its been taken care of I wouldn't worry about it. You could also do a budget stroker for around 2k parts and labor and get your compression up to where lloyd likes them to be. On the oher hand, I have seen lt1's spin rod bearings after just a hot cam install... Its a crap shoot IMO
Old May 2, 2010 | 12:29 PM
pillarpod's Avatar
i wouldn't touch it
Old May 2, 2010 | 12:58 PM
Z28Roxy's Avatar
Do it if you're prepared if it blows up. Not to scare you but if it's your DD or you don't have the money for a rebuild, don't do it. If you do, put the new top end and see how long it lasts. Could be 5 minutes or 50,000 miles.
Old May 2, 2010 | 01:29 PM
udlose99ta's Avatar
thats a great way to put it
Old May 2, 2010 | 01:36 PM
imthat1guy's Avatar
Just do it and if something does happen make it bigger and better !
Old May 2, 2010 | 03:04 PM
Dadic 78's Avatar
The car has 190,000 Km on it, I'm the second owner. It's been taken care of, with a bit of fun, of course... It's not a DD, just a summer fun-car. So, I think I'll keep the budget-friendly approach going, and just install the LE2 top end, and giv'er ****. We'll see how she goes!
Old May 2, 2010 | 03:12 PM
1redta's Avatar
Mine spun a bearing after a hotcam install with 80,000 miles on the motor. Have had plenty of lt experience, sometimes you get dirt in the wrong place I'd have money saved up to redo the bottom. I went stock crank 6"eagle SIR mahle power pack LE2 set up
Old May 2, 2010 | 03:18 PM
imthat1guy's Avatar
Well theres slow factory cars and then theres bullet proof factory cars that take so much abuse and make great power you'll just have to find out.
Old May 2, 2010 | 03:25 PM
Dadic 78's Avatar
My car is the emotional bitch that rolled off the factory line... She's tempermental, moody, bitchy, and occasionally, f**king awesome! Maybe I should rebuild the bottom end too, just to make sure...
Where are you guys getting your bottom ends?
Old May 2, 2010 | 03:49 PM
udlose99ta's Avatar
you can get a budget eagle 383 rotating assembly off ebay for like 800 bucks. Figure 800-1000 for machine work. Whatever you decide to do, talk to Lloyd first because he can tell you the best compression ratio your le2 top end will like best. End up with one of the 430rwhp lt1's!1
Old May 2, 2010 | 03:53 PM
marc97taws6's Avatar
Talk to LE. I would avoid the cheap rebuilds on Ebay. You should build it once and build it right so you don't have to worry about building it again. I think LE would recommend a 355 stroker rebuild. That is what I am going to be eventually doing.
Just realize that once you start building the car with that power on your m6, your 10-bolt is likely on borrowed time. I would recommend getting a rear-end girdle as a starting point for your rear just as added security until you end up dropping the money on a new one
Old May 2, 2010 | 04:05 PM
RamAir95TA's Avatar
I'd trust a 120k mile short-block before I trusted budget Eagle cast crap.
Old May 2, 2010 | 04:06 PM
x2, x3, ..... x(infinity).., Facebook: Like
Old May 2, 2010 | 04:16 PM
dangalla's Avatar
the important part of this sentence is the word "cast", alot of people used eagle forged cranks with no issues, but there not the best mind you.
but many people have broken the cast units under minimal stress, and you would be better off stock
