Are UMI LCA Relocation brakets the same for a 10 as for a 12bolt
Old May 2, 2010 | 05:00 PM
aug181983's Avatar
Default Are UMI LCA Relocation brakets the same for a 10 as for a 12bolt
Are UMI LCA Relocation brakets the same for a 10 as for a 12bolt.
I just got a 12 bolt and need to make sure I order the right part.
Thanks
Old May 2, 2010 | 10:00 PM
SPEED#1's Avatar
I believe they are the same part number
Old May 2, 2010 | 10:04 PM
GIZMO's Avatar
What makes you think that you need them?
Old May 2, 2010 | 10:27 PM
aug181983's Avatar
My car is lowered in the front and rear. So I definately need them.
Old May 3, 2010 | 01:16 AM
aug181983's Avatar
bump.....
Old May 3, 2010 | 07:53 AM
always faster's Avatar
Depend on wich 12 bolts i think.
The STRANGE 12 bolts got the same axle tube diameter as the 10 bolts so it is the same relocation brackets.
*correct me if im wrong here dont just bash ok *
but the Moser 12 bolts got bigger axle tube and required some optional rear sway bar mounting kit so it should also need a different relocation bracket...
Old May 3, 2010 | 08:09 AM
UMI Performance's Avatar
Hello,
If it is a Strange 12-bolt then the brackets for the stock rear end will bolt right up. This includes our weld in brackets and bolt on brackets.
If it is a Moser 12-bolt you need these brackets- www.umiperformance.com/2011
If you have any questions please let me know. Thank you!
Ryan
Old May 3, 2010 | 08:28 AM
GIZMO's Avatar
What is your current lower control arm angle?
Old May 3, 2010 | 10:09 PM
robsquikz28's Avatar
I pmd the guy and he has a 12 bolt MOSER and it only has 1 bolt hole for him to mount the lcas. So he definately needs the umi bracket to retain instant center and the correct geometry.
Old May 3, 2010 | 10:37 PM
1961ba427's Avatar
Originally Posted by UMI Performance
Hello,
Ryan
Ryan, Hey man. You may not know me, but you have been a huge help with my 61 Bel Air in the past. Waited forever for ya'll to come out with the double adj uca. Well worth the wait. Car has bolt in coil overs designed by myself now. Glad to see you on this board. Thanks, Jason
