Which timing set to get for cam swap?
Old May 4, 2010 | 07:52 PM
kgkern01's Avatar
Default Which timing set to get for cam swap?
I am doing a heads/cam swap onto a 53k mile shortblock, that is without a timing set. I have the old timing set off of my 171k engine, but I feel that it is probably too worn out to use again. I have read that the stock GM set is more than sufficient for a heads/cam build, but which should I go with? Should I reuse the gears and just get a new chain, new GM full timing set or Lunati set ($99.95 Summit)?
Old May 4, 2010 | 08:28 PM
dangalla's Avatar
you should always replace them as a set
Old May 4, 2010 | 11:55 PM
kgkern01's Avatar
That's what I was probably going to do anyway. So which set should I get?
Old May 5, 2010 | 02:32 AM
gregrob's Avatar
Cam sprocket - part #: 10128349
Crank sprocket - part #: 10128346
Chain - part #: 10128485
All GM. Just order it from Summit
Old May 5, 2010 | 06:56 PM
1redta's Avatar
I put a rollermaster in my car
Old May 6, 2010 | 06:15 AM
kgkern01's Avatar
So $160 for a stock GM timing set from Summit? Seems a little high to me, would the Lunati set not be just as good for $100?
Old May 6, 2010 | 02:13 PM
I8ASaleen's Avatar
Make sure it has the provision for a waterpump, that is if you don't have an EWP.
Old May 6, 2010 | 02:15 PM
31camaro's Avatar
i just got a new chain for mine when i did my h/c/i, no need to replace the gears since they are steel
Old May 6, 2010 | 02:39 PM
deerslayinrednek's Avatar
thats what i want to do but everyone told me not to, so now idk what to do. I wont put the new gears, so it's either a new chain with the old gears or my old chain and old gears
Old May 6, 2010 | 03:38 PM
RamAir95TA's Avatar
It is foolish to think that there would be no wear on the sprockets. It's metal to metal. The chain and sprockets wear together. I highly suggest that anyone who reads this opts to change the chain AND sprockets.
