EGR Delete and Trouble Starting
Old May 7, 2010 | 12:17 PM
94PTA's Avatar
Question EGR Delete and Trouble Starting
I recently started to fix up my old 94 Trans AM (LT1). I have replaced the opti spark, wires, plugs, o2 sensors, timing set, various gaskets and installed Pace Setter LTs. When installing the headers I deleted the pipe that goes from the header to the intake manifold. However, I did not delete the EGR valve. Will this cause a problem when getting the car tuned? Also, now when I go to start the car it turns over for about 20 seconds before firing up. It seems to idle fine but runs pretty crappy when accelerating. This was not a problem before I did the work so I don’t think it is a fuel pump/filter issue. Does anyone know if this is normal for the mods I have made? Will a tune fix me rt up? I am trying to make sure that it is most likely a tune issue before going through the trouble of getting it to the tune shop and wasting time and money.
Also, I found a tune shop that said they would tune my car but I needed to buy the software (LT1 Edit). What is the best way to go about doing this. What EXACTLY do I need?
Thanks guys!
Old May 7, 2010 | 12:44 PM
MICHZ28's Avatar
Did you plug the hole in the back of the intake?
Old May 7, 2010 | 03:35 PM
94PTA's Avatar
Yes- I did put a plate over the hole on the intake manifold. Do I need to remove the EGR and put a plate on it as well? Are there any pros and cons associated with this?
