LS1 lifters?!
Not every motor is geometrically identical, that's why they make pushrod length checking tools. I see that your heads are ported which probably means they've been resurfaced and/or milled. That in combination with the Impala head gaskets should be more than enough reason for you to measure yourself. Why take a chance?
See what I'm getting at? To do it right, you have to measure.
As Ramair already said, . . . . . measure.
1.) Use the Impala gaskets. You'll need to put them on, then check for proper pushrod length (BY MEASURING). Your magical pushrods you have now may or may not work. If they aren't the right length, SELL THEM (budget is a concern, right?). Get the right pushrods (a measly $40) and enjoy a few extra ponies from a tighter quench and a bump in compression. AWESOME!!!!!!!!!!!!!!!!!!!!!
2.) Use stock thickness gaskets. Then measure again. Your magical pushrods you have now may or may not be the right length. If they are, hooray! If not, well, don't you wish you went with option 1? You'd be giving up some HP. But at least your super awesome pushrods you have now would have a home.
Apparently an increase in HP isn't worth $40 to you. :facepalm: I give up. It's your build - do what you want. I'll never understand why people come on here asking for advice and then, when they get it, they fight and cry about what's given because it isn't what they want to hear.
There are several different things that effect the correct pushrod length. So because the STOCK length rods worked for me doesn't mean they'll work for you. I found my correct pushrod length by measuring, using an adjustable pushrod.
One of the things I often read from the camshaft companies is NOT to ASSUME that since a certain length works for one specific application it'll also work for yours.
BOTTOM LINE IS TO MEASURE.
Jake
