Scanmaster Hook -up OBD2 PLUG?
Old May 8, 2010 | 07:40 PM
detroit_903's Avatar
Default Scanmaster Hook -up OBD2 PLUG?
Have a 95 z28 OBD-2 Port with a OBD-1 Computer. Want to hook up my scanmaster to a OBD-2 plug so it's a direct plug in. Are these color codes right?
Scanmaster RED wire to Orange wire(Plug)
Black wire to Black wire (plug)
White wire to Tan wire(plug)
Once again this is OBD-2 port with a OBD-1 pcm. Please let me know if I have the right hook-up
Old May 10, 2010 | 12:23 PM
Trine430's Avatar
Default Scanmaster Hookup
I am not sure about the colors but I just did the same thing on my 95. I soldered the Scanmaster wires to an OBDII plug so I could switch between it and my ALDL cable for my laptop. Looking at the OBDII style connector under the dash I wired it up in the following way:
_______________________
| 1| 2| 3| 4| 5| 6| 7| 8|
|9|10|11|12|13|14|15|16|
  1. Black wire - Pin 5
  2. White wire - Pin 9
  3. Red wire - Pin 16
Hope this helps
Old May 10, 2010 | 12:26 PM
RamAir95TA's Avatar
This might help as well: http://shbox.com/1/xraycable.jpg
