Codes 36 and 42
95 Z28
385
Ported stock heads and intake 2.02/1.60
58 mm TB
42lb SVOs
Lunati 60123
Thanks
Sean
42; Ignition Control Ground Circuit (check ICM wiring, test resistance using shbox's procedure: http://shbox.com/1/4th_gen_tech2.html#opti_test)
If everything looks ok after troubleshooting, reset the PCM by disconnecting batt. ground for a few minutes and then drive and look for the return of codes...
Best of luck. This pair of codes ended in an Opti replacement for me a couple of weeks ago.
