relocated battery, now having trouble with alternator
i relocated the battery to the trunk of the car, and i ran the battery cable from the trunk to the little red power distribution box (on the passenger side of the engine bay), i then ran a cable from the starter to that same red power distribution box, and i also did the same for the alternator, but idk if thats where i should run it...
to anyone else that has relocated their battery, how did you guys run that cable from the alternator that used to go straight to the battery??
ok thanks guys
i forgot to mention that my alternator has gone crazy, and i dont know why
lets say that i turn the car on, well the alternator scream really really loud, but idk why, whats wierd is that it only does it when i plug in that connection that goes from the wiring harness to the alternator, i unplug it and it stops, it also gets super hot, i cant even touch it cause it burns
i got it rebuilt, still does it
i swapped it with a good one from my other car (a 95z), and it made it do the same
what could be going on here
