Does AFR offer a 210cc head for LT1?
Old May 11, 2010 | 10:11 PM
tscheu5452's Avatar
Default Does AFR offer a 210cc head for LT1?
Looking to upgrade my combo. Current heads are worked over (by LPE) stock heads. Need help on what I should choose for my 383. AFR 195s or 210s? A buddy told me there aren't 210s for the LT1.
Old May 11, 2010 | 10:17 PM
thehammer69's Avatar
http://www.airflowresearch.com/index.php?cPath=27_57
Old May 11, 2010 | 10:47 PM
slomarao's Avatar
depending on your goals the 220's may be in order. Mostlikely the 210;s will take care of your needs.
Have you looked at TFS??
Old May 12, 2010 | 05:00 AM
Wicked94Z's Avatar
see sig... mine are about 218cc intake runner. The original afr 210 race castings were only a 70% finished port, and were about 200cc. That said, 18cc is ALOT to take out of an intake port.
Old May 12, 2010 | 03:20 PM
tscheu5452's Avatar
Thanks guys. Also looking at Trick Flow 220cc. Leaning that direction now that I see they are about $600 cheaper.
Old May 12, 2010 | 03:45 PM
Puck's Avatar
220s are the old discontinued castings, and the big 227s are really for all-out builds...you will need to pay special attention to the valvetrian and valve covers used due to the need for offset rockers, and an LT1 manifold wont work without modding.
*nods*, my 220s had 7cc's taken out, ending up at 227cc's after porting.
The real question is, what are your goals? Will you run them out of the box, or ported?
