milling heads
Here's a good article that talks about the procceses available:
http://www.aa1car.com/library/ar996.htm
Also look at how deck height affects compression. And piston shape, pin height, head gasket thickness, etc. etc.
Why do you ask?
had to "modify" the intake Manifold to get it to go back on. I had to run 93 in the car because it would diesal and spark knock with anything less.
I'm curious to the PTV I'll have
Milling more then .010 on an SBC is not dangerous. You should always check PTV anyway...
BTW, each .005-.006 is around one cc drop in chamber size. You can only flat mill down around .050 before seriously screwing up your intake seal, but you can angle mill farther then that.
