LT1 longtube problems
Old May 12, 2010 | 06:08 PM
lethal bird's Avatar
Default LT1 longtube problems
ok i go to put my longtubes on and they hit the a/c pipe. We bent the pipe out of the way so we could get the longtubes on. now that the headers are on the a/c pipe and the headers are touching. I live in Ms and dont have t tops and i drive the car regular so i cant ditch the a/c. so i need to advice and suggestions.
Old May 12, 2010 | 06:13 PM
jay7199's Avatar
pictures of the problem? what headers do you have?
Old May 12, 2010 | 06:24 PM
i dont have any pic. but they pacesetters
Old May 12, 2010 | 07:02 PM
old93camaro's Avatar
are you talking about the pipes that tuck or lay against the pass side????? if so there is no reason they should be touching unless the lines are unbolted from the side wall and hanging out
Old May 12, 2010 | 08:00 PM
the pipe that connects to the compressor and has a u bend in it
Old May 12, 2010 | 09:46 PM
lt11994's Avatar
Like previously said they shouldnt be touching the headers.
I am sure you're talking about the tubing where the number 28 is located on that diagram. I did have to remove that fitting but that was only to take out the huge bolt from the motor mount.
Old May 12, 2010 | 10:19 PM
yes thats where im talking about. but they are touching. i was think maybe i could just bend the pipe down a little and wrap it good in head sheathing.
