Erase codes from Scanmaster?
Old May 12, 2010 | 08:42 PM
detroit_903's Avatar
Default Erase codes from Scanmaster?
Picked up a scanmaster for my lt1. Has some trouble codes stored into the scanmaster. Unplugged the battery terminals and still codes pop up. Does anyone know how to erase these codes. Is there a button I could push or fuse to pull to erase them?
Old May 13, 2010 | 12:54 PM
Drew24's Avatar
Are you sure you fixed why the code is there? What is the code that you are getting?
Old May 13, 2010 | 05:39 PM
Dadic 78's Avatar
The code will erase if you disconnect your battery, but if the issue is still there, then the computer will flash your SES light again. You need to determine why the code is coming up, and fix it for it to go away.
Old May 13, 2010 | 08:09 PM
I tried disconnecting the battery for 30min. The scanmaster still pops on a couple codes without even me starting the car up. When I first hooked it up the codes were already stored in the scanmaster. DTC 55 DTC18 pops up. But like I said I just turn the ign. on and I'm getting those codes - Is there anyway to erase this codes
