Long start up on LT1
My friend has a 94 LT1 Camaro that has developed a long start problem.
I initially thought it was the fuel pump because pressure at the schrader valve would take a long time to build up and then drop rather quickly. I replaced the fuel pump with a walbro 255LPH pump, problem still there. I then figured it might have been the fuel pressure regulator, I tested that both with the car running and off, and the fuel pressure regulator is functioning as it should. I then checked fuel pressure at the schrader valve again, it was still dropping off to 0 with in a second or two of the key being turned to run. Then, the car developed a hesitation below 2000 rpm, so I believed it was the injectors. Today, I pulled the fuel rail half off and saw that the front 4 injectors are not leaking and working properly, the back 4 injectors where not tested. I did notice that the vacuum lines coming to and from the evap purge solenoid were cracked. I replaced the evap vacuum lines and the car no longer has a hesitation, but it is still taking a long time to start. I never replaced the fuel filter because I felt that the problem wouldn't happen just on start up, but could it have been that simple all along? Was there a return fuel line that I accidentally forgot to block off when I installed the walbro fuel pump?
The only two things left that I could think of that would cause the problems are : clogged fuel filter, bad evap purge solenoid(but I dont think this would affect start up).
Also, if the key is cycled 4 or 5 times, the fuel pump is kicked on enough that the car will almost start immediately, but the longer the car sits, the longer it takes to start.
Leaking fuel pump check ball (integral to the pump).
Leaking fuel pump flex pipe.
Leaking valve/seat within pressure regulator.
Leaking injector(s).
Just because a part is new doesn't mean it is invincible and can't be faulty. Walbro 255s can go bad. I will agree that that is a LOT of pressure to bleed down from leaky injectors (I suppose it could be possible). How did you test the injectors? The best thing to do is to remove the rail and prime the system and visually look to see if any of them are dripping.
Also, since you had the pump out, if the flex hose was leaky and/or not sealed properly then that can cause a leak-down.
Could any of the possibilities causing this issue mentioned above make a fuel pump fail prematurely?
