lt1 swap
Old May 14, 2010 | 03:23 PM
blk96z07's Avatar
Default lt1 swap
i need some help, i have a 97 v6 camaro i just got and been wanting to swap everything over on my old trans am.. i need to know do i gotta change the wiring inside the car? i know everything from under the hood but im lost on wiring!
Old May 14, 2010 | 06:22 PM
boosted LT1's Avatar
The LT1 harness is essentially independent once it gets power (battery and ignition) and ground. The wire to the starter and the alternator are there already from the motor that was in there. The engine doesn't care what car it is in so the rest of the car's wiring has no real impact to the engine other than the load on the alternator and ac request and compressor status etc...
I have transplanted a couple LT1's into datsuns and a gmc truck. The easiest way is to go to shbox he has a site with many procedures to check an lt1 and he also has the wiring diagrams.
Good luck
