Please look at these pictures. I've switched from m6 to th350. Question about wires.
Old 05-14-2010, 10:55 PM
djm_e22's Avatar
Default Please look at these pictures. I've switched from m6 to th350. Question about wires.
First sorry about the pictures being so big. I was using imageshack and can't
remember how to decrease the size. Anyhow I got a 96 lt1 that I have
switched from an m6 to a th350 and I am trying to get the car to start up.
I can't figure which wires are the clutch wires. I also have several other
pictures of wires I can't seem to find where they go. All these wires are
underneath the steering column if you can't tell.
This first one I thought was the clutch wires so I cut the connector and tired
them together but the car didn't start. Do you know what this one is?
Uploaded with ImageShack.us
I am not sure where this even goes? What is this?
This looked to come off of the break pedal. What is it for?
Old 05-15-2010, 07:11 AM
djm_e22's Avatar
Anybody? Sorry I'm a little desperate we are in the process of moving to another house and I can't get this car started.
Old 05-15-2010, 07:14 AM
the_merv's Avatar
That one that came off of the Brake Pedal looks like the cruise disengage.
That one with the big Yellow and Brown is the one that looks to plug into the N/S Switch..connect them 2 and see what happens.
Old 05-15-2010, 07:18 AM
Joshiedoom's Avatar
Subscribed
Old 05-15-2010, 10:23 AM
JB_97ws6TA's Avatar
not sure about the smaller guage because I can't really see where it came from but the connector looks correct for cruise control disconnect and if it was attached to the clutch on a clutch anticipation switch than that is definately what it is. As for the larger connector merv is correct again, that is your clutch start switch connector and it needs to either be wired into a park/neutral switch or spliced together to get the car to turn over.
Old 05-15-2010, 10:38 AM
Village Troll
SS RRR's Avatar
The first pic looks like speaker wire...
Old 05-15-2010, 03:40 PM
djm_e22's Avatar
Thanks everybody!! My car is up and running!!
Quick Reply: Please look at these pictures. I've switched from m6 to th350. Question about wires.
