Need help car wont idle
Old May 16, 2010 | 10:46 AM
kierstyn's Avatar
Default Need help car wont idle
Ok heres the problem I can start the car and it will idle fine. When I drive down the road and go to stop it wants to idle down and die. The car is h/c with 52mm tb it has been tuned for all this and ran right before but started doing this recently. I have checked fuel pressure and changed the filter with no change. Anyone have any ideas?
Old May 16, 2010 | 10:52 AM
mike mlodecki's Avatar
i had my idle messed up as well after the tune, sometimes it just forgets the tune(idle) call your speed shop where you got the tune and im sure they can just adjust it again.
Old May 16, 2010 | 12:36 PM
RamAir95TA's Avatar
What year, mods, etc.?
You need to get a scanner on the IAC follower tables and see what you come up with.
Old May 16, 2010 | 08:41 PM
kierstyn's Avatar
94 model h/c car 52mm tb full boltons longtubes no egr crap. Anything else you need info on? It was tuned by a local shop and ran fine for over a year with the tune. Kinda crazy I guess.
Old May 16, 2010 | 08:48 PM
RamAir95TA's Avatar
Yeah, you'll need to get a scanner on it to check the IAC.
Old May 17, 2010 | 03:49 AM
kierstyn's Avatar
Ok i will try that and see whats up.
