need help.. maybe i screwed the engine?
Old May 17, 2010 | 05:36 PM
brianfromhawaii's Avatar
Default need help.. maybe i screwed the engine?
so my buddys 350 vette didnt run for a while so i went ahead and diagnosed it down to a fuel pump, replaced the pump and it fired right up, so he goes ripping around the property (it has 112k miles) and all of a sudden after a bunch of WOT it stumbles to its death.... we went to start it again and it kinda makes a "bloop bloop bloop" noise and flames shoot out of the exhaust.. it will not start... im thinking it jumped a link on the timing chain... you guys?
Old May 17, 2010 | 07:10 PM
86formula's Avatar
whats "a while"?
Old May 17, 2010 | 07:18 PM
defaultexistence's Avatar
Originally Posted by 86formula
whats "a while"?
X2?
not the greatest idea in the world to WOT an engine that has not ran in "A While" start by checking ignition, fuel press, ses codes....ect
I'll start the bidding at $1000
Old May 17, 2010 | 11:31 PM
MasterTomos's Avatar
more than likely an opti...
Old May 17, 2010 | 11:41 PM
x2 indeed.....
Old May 18, 2010 | 12:02 AM
distributor.. no opti.... 3 minutes..
Old May 18, 2010 | 08:53 AM
RamAir95TA's Avatar
Old May 18, 2010 | 01:42 PM
TDavanzo's Avatar
If the chain was loose enough for it to jump a link you'd have a pretty big pile of failure on your hands.
Old May 18, 2010 | 01:56 PM
gregrob's Avatar
Whatthefuck
Old May 18, 2010 | 02:21 PM
draggin97s10's Avatar
hes saying 3 minutes WOT and it has a distr so its carbd? lol
Old May 18, 2010 | 02:22 PM
what years the car
Old May 18, 2010 | 02:24 PM
Originally Posted by RamAir95TA
it has a distributor no optispark... its an old 350.... and he was doing wot around the yard for maybe 3 min
its an 84... cross fire injection, just cuz it has a distributor doesnt mean its not efi lol
Old May 18, 2010 | 02:27 PM
no i know that but if its an LT1 which is the section your in it most LIKELY has a carb if it has a dizzy thank you though i didnt know GM made anything efi with a dizzy. LMAO
Old May 18, 2010 | 02:28 PM
but now. if it wont start check the simple **** first. spark fuel compression
Old May 18, 2010 | 03:27 PM
fuel for sure, i can see it shooting fuel, definitly has spark, but compression is a no, i think it jumped a link, just want other opinions...
Old May 18, 2010 | 04:09 PM
fleetmgr's Avatar
Put a socket on the balancer bolt and rock it back and forth until you see the rotor start to turn. If it's more than just a very few degrees, I'd say you did because the only way it should jump is with really sloppy chain.
Old May 18, 2010 | 06:21 PM
lol FYI,...im sure you know this but... just because it is "shooting fuel" doesn't mean it is pressurising. if you don't have compression then look no further find out why there is no compression ,hopefully there's no bent valves. good luck
Old May 18, 2010 | 06:32 PM
ok got ya ill try that when i get to the car... good idea man!
also to the guy about the fuel, its crossfire injection, you can literally take a can of gas and pour it on the throttle body blades and it will atomize it lol.... its BULLSHIT but its getting enough fuel to run.
