1le intake elbow
some may argue that certain elbows "flow better", which is a joke IMO...id bet money that it will not make a noticeable difference on the road, on the track, or at the dyno.
Also, someone mentioned drilling a hole for the opti-vent. When I bought my cai and trick flow elbow used from a member on here a few months back, the elbow also wasn't drilled so.....after a quick brain storm....I poked a hole in the 5/8" heater hose bypass cap that is plugging the AIR pipe fitting on the CAI and stuck the plastic vacuum elbow into the end of it. Has worked fine so far, and should see the same amount of vac as putting it on the other side of the MAF.
It's also made of the same rubber crap that tears over time...
