Digital 6 MSD Install Help
Old May 21, 2010 | 03:53 PM
flatbird's Avatar
Default Digital 6 MSD Install Help
I was planning on purchasing a new coil and ICM, but it looks like I could go digital MSD for just a little more. What do I need and what process do I go through to perform a successful installation. Also, how is the reliability of them? Thanks...
Old May 21, 2010 | 04:21 PM
Speed Density's Avatar
hashtagBMW
Well, you get instructions when you buy the unit. That should help you install it. And you can either splice/solder into the coil wires or buy the $30 coil splice kit that MSD offers.
Old May 21, 2010 | 09:22 PM
fex77k's Avatar
Its pretty simple if you get the harness that plugs in on the coil, then all you have to do is connect two wires to the harness and give it a 12v and a ground and your good. I've had mine in my car for 3 years and I bought it used, its a great system but if your not going to use the extra features then it's a bit overkill. The best part about it is the fact that you don't have to buy the pills, everything is adjustable with a flathead. Keep it dry and mount it on the rubber shocks and you souldn't have any issues with it.
Old May 21, 2010 | 10:07 PM
Wicked94Z's Avatar
My msd box was worth less than 1hp on my motor at 7k rpms, so I'd suggest spending your money elsewhere unless you plan on running nitrous.
Old May 22, 2010 | 12:33 AM
JB_97ws6TA's Avatar
An MSD box is not in lieu of you stock ignition components, if you are in need of a new coil and ICM, once you install the ignition box you will still be in need of a new coil and ICM.
while I agree with you that an ignition is not going to increase peak hp, it seems that your post suggested the box is useless which on that I would have to disagree. It helped smooth out my idle and part throttle as well as slightly increased my gas mileage on the freeway. I purchased the box for the rev limiters and to help drivability due to the low rpm smoothing that the box does accomplish
Here is where I mounted mine
Old May 22, 2010 | 02:59 AM
Wicked94Z's Avatar
Lets just say it hypothetically increases highway gas mileage 1 mpg, which i highly doubt it would. How long would it take to pay off that 300 dollar ignition box? i'll still classify it as a pointless mod.
Old May 22, 2010 | 08:50 AM
JB_97ws6TA's Avatar
having a 2 step rev limiter in a six speed yeah you're right that sounds stupid And I guess the box did absolutely nothing to smooth your idle then either, did someone over at MSD offend you or something?
Old May 22, 2010 | 05:38 PM
Wicked94Z's Avatar
i didn't really care about having a smooth idle... i had like 30 degrees of overlap. New cam has like 60 degrees of overlap @ .050 so I doubt it'd be noticeable 2 step... yea the guy is running 17" street tires and an ls1 aluminum driveshaft I'm sure that 2 step would be real useful.
Old May 23, 2010 | 10:08 PM
fex77k's Avatar
It smoothed out my stock motors idle but thats it, the only reason I have one is because I got it for around as much as a new 6AL cost.
