Does this sound like slave cyl?
Old May 22, 2010 | 12:58 PM
nik1703's Avatar
Default Does this sound like slave cyl?
When i hold the clutch down longer than usual (at a light or something, or backing up) it seems to lose pressure. it'll grip really far down and only go up half way, once i release it, then slowly inch its way back up. under normal driving though it doesnt do that, only if i hold it down longer than usual.
does it sound like the slave?
Old May 22, 2010 | 02:08 PM
nik1703's Avatar
anyone?
Old May 22, 2010 | 02:19 PM
nik1703's Avatar
or master?
Old May 22, 2010 | 02:26 PM
jay7199's Avatar
it sounds like the slave, check the lines for leaks. lt1s clutch setup is alot better then the ls1 and I don't hear about to many problems with them. The good news is they are alot easyer to change then a ls1 slave also.
But yeah, check the lines and see what color your fluid is. Might just be time to bleed the system and see how it does.
Old May 22, 2010 | 02:29 PM
nik1703's Avatar
ok cool... will bleed the slave and see what happens.
which reservoir is the one for the clutch? i know there are two hydraulic reservoirs. i am guessing it is the lower one?
jay7199's Avatar
the small white on to the right of the brake master
Old May 23, 2010 | 10:13 PM
fex77k's Avatar
The whole assembly cost around 200 new from GM so try not to mess it up. Make sure the fluid is full and its not dirty if your going to bleed it.
Old May 24, 2010 | 04:05 PM
nik1703's Avatar
Ok so a few things..
got under the car to bleed it and realized immediately that the slave was leaking... so that's that, i need a new slave. $50 bucks at autozone.
I realized the slaves on these cars have no bleeder valve, how the hell do i bleed it once i pick up a new slave? is there a way to do it without buying one of those vacuum things?
Old May 24, 2010 | 05:17 PM
fex77k's Avatar
There is a roll pin you have to press out to get the old one out, the only way to bleed it is to bench bleed it or install it and get ready for a sore left foot.
Old May 24, 2010 | 05:29 PM
nik1703's Avatar
Roll pin? is that inside the hydraulic line connecting to the slave? How do you bench bleed it?
Old May 24, 2010 | 05:51 PM
fex77k's Avatar
This is what your going to get from the store. Make sure the resivor is full when you bleed it. If you bench bleed it I usually use a vice, but be carefull cause its all plastic and you don't want to break it.
