95 lt1 cooling issue
http://shbox.com/1/4th_gen_tech2.html#radflush
Also, I should probably add that it is misfiring as well, which I have a suspicion is a plug wire in the wrong place or not on all the way, but thought that there was a possibility it was related.
http://shbox.com/1/low_coolant.jpg
The very top hose that you see (the top port closes to the radiator cap) is for the overflow tank. The one right below that is for the TB return hose.
Its running much cooler now! And both bleeders bleed out a steady stream and the overflow isnt... overflowing anymore lol. So now we need to adjust the rockers again and find out what the problem is with the misfire. We'll keep this thread updated with any questions or what we find with the misfire. Thanks for the help so far!
