Swapping from OB1 to OBD2?
Old May 26, 2010 | 10:53 AM
ss.slp.ls1's Avatar
Originally Posted by moehorsepower
First off, do you really need to spin the motor past the 72 mark? I mean you did check it and it is making power up and past that point? The reason I ask is because I have had so many customers with setups that the shop/builder say it should make power up to 7000+ when they were all over with by like 6300 or so. I am talking about motors with very large cams, heads ect. even solid rollers.
That's a good question.
Old May 26, 2010 | 10:54 AM
T/ALT1's Avatar
First off, do you really need to spin the motor past the 72 mark? I mean you did check it and it is making power up and past that point? The reason I ask is because I have had so many customers with setups that the shop/builder say it should make power up to 7000+ when they were all over with by like 6300 or so. I am talking about motors with very large cams, heads ect. even solid rollers. Also on the OBD1 PCM's running up to 7200 RPM's, I have never had one that didn't go past that. Granted is was only a few but I never had one that hit a so called rev limiter....
Yes, on the dyno my horsepower curve was still going up until 6900rpms where it hit a rev limiter. I only want to go to 7200-7300 for a little over rev and plan on shifting@7k if possible thats it. Where do you tune in Texas?
Old May 26, 2010 | 10:38 PM
TravisMcGill2000's Avatar
so they are or are not a rev limiter. Sorry guys
Old May 27, 2010 | 06:10 AM
moehorsepower's Avatar
Well, Like I said, I have never had one that stopped at 6900 RPM's, Maybe just lucky?? and the ones that did rev to 7200 kept the fuel curve in line. Yes the fuel will try and maintain the last cell that is commanded and theoretically follow the continues path, How far?? Don't know since these motors did fine up to the 7200 mark..
Old May 27, 2010 | 07:28 AM
Wicked94Z's Avatar
look at the dyno graphs....
http://advancedinduction.com/Abare.html
