Find my vacuum leak!
One quick and dirty way to find a vacuum leak is to use a can of brake cleaner/carb cleaner and spray it around the perimeter of the intake manifold sealing surface and around the intake elbow after the MAF. If the idle goes up, you've found your leak.
Make sure all of the little metal nipples are plug off or being used.
Make sure that the PCV hose is there and routed correctly.
You didn't forget the donkey dick in the intake elbow did you ?
Here are some pics, make sure everything is there or plugged off.
http://shbox.com/1/pcv.jpg
http://shbox.com/1/egr1.jpg
http://shbox.com/1/evap_sol.jpg
http://shbox.com/1/tps.jpg
