1994 procharged z28
1994 Chevy Camaro Z-28. It is a 6 speed, hardtop, approx 72K original miles with many modifications:
ENGINE / TRANSMISSION:
1. PROCHARGER / ATI Intercooled P 600-B Kit set up for 9lbs of boost
2. LT1 355 - JE forged aluminum pistons, eagle rods, CNC Heads are matched, with Custom grind cam, Crane Gold Series 1.6ratio roller rockers
3. MSD ignition (coil and boost timing master)
4. New GM Delco Optispark
5. New Lunati Timing chain
6. Factory 6 speed transmission with skip shift eliminator installed
7. New Spec Steel Flywheel
8. New Stage 3 Spec Clutch with "I" option (good for 800whp)
9. Keyed Fluid Dampener harmonic balancer
10. BBK 58mm throttle body
EXHAUST:
11. SLP Short Equal Length Headers, SLP Downpipe, Random Technologies Cat
12. 3” Borla Cat-back exhaust
BODY/INTERIOR:
13. 8 Point welded in roll cage
14. Welded in sub-frame connectors
15. Cadillac Pearl White w/blue tint, single blue stripe
16. Fiberglass SS hood and suncoast spoiler
17. White Face gauge overlay
18. Dual A pillar gauge pods with boost and air ratio
MISC:
19. Corvette Rims 17's front 18's rear, comes with an extra set of rear tires with about 60% tread life remaining
20. Drive Shaft Loop
21. In tank Walbro fuel pump with a inline piggy back pump (from Procharger kit charger)
22. Aftermarket alarm system.
23. A/C condenser and lines were removed and replaced, but no R-134a was reinstalled. The system should work.
24. New set of front and rear lowering springs (1 ½”) are in the trunk ready to be installed.
what will this be putting out and what can i do to add hp and tq
EXHAUST:
BODY/INTERIOR:
MISC:
2) Ditch those shitty SLP shorties and get some quality long tube headers. That in itself will yeild a huge gain. Ditch the cats and get yourself an electric cutout.
