GM847 camshaft: Pros and Cons?
steve, I guess if the 180s you have flow just as good at say .550 lift as the 200s, then 180s might run a little better and have a better throttle response since they are smaller. I think I might re-port mine to about 190-195 and put 2.080/1.600 valves in sometime soon. Then I'll do the cam at the same time.
