LT1 1995 Z28 fuel pump problem
Old May 28, 2010 | 12:39 AM
keycool1's Avatar
Default LT1 1995 Z28 fuel pump problem
I have a 1995 Z28 Camaro LT1, it was running fine, until I let it sit up for about 8 months. Now the fuel pump wont make a sound or come on. I even tried applying voltage directly to the wire next to the ECM that bypasses the relays.
My question is can sitting up for 8 months without starting the car kill the fuel pump? Thanks for any ideas.
Old May 28, 2010 | 12:41 AM
RamAir95TA's Avatar
When it sat, how much fuel was in the tank?
Old May 28, 2010 | 12:52 AM
robsquikz28's Avatar
x2 with Joe. ALso did it have power and ground to the pump? DId it do anything when you applied power?
Old May 28, 2010 | 12:53 AM
keycool1's Avatar
maby one fourth a tank, not to much
Old May 28, 2010 | 12:54 AM
keycool1's Avatar
did not do anything
Old May 28, 2010 | 12:55 AM
keycool1's Avatar
yes it had power and groung
Old May 28, 2010 | 12:56 AM
With that little fuel it definately could have destroyed the pump. Id say its time for a new one.
Old May 28, 2010 | 12:59 AM
keycool1's Avatar
will they just lock up?
Old May 28, 2010 | 01:00 AM
RamAir95TA's Avatar
When they are low on fuel, the pump is exposed. If left exposed for too long, the internals of the pump can start to oxidize and rust, resulting in failure.
Old May 28, 2010 | 01:02 AM
keycool1's Avatar
ok thanks for the info, I got 200,000 miles out of that pump so I might go back stock.
