what spark plugs?
Old May 28, 2010 | 01:58 PM
95Z28420's Avatar
Default what spark plugs?
i have a 95 Z28 and i have a head cam swap with full exhaust bigger fuel pump injectors and so on i am making 420 horsepower at the tires. would the stock heat range spark plug work or should i get one heat range colder which i believe is in the car i cant remember. i am doing this because i have a plug wire arching bad so im just going to change the plugs and wires
Old May 28, 2010 | 02:13 PM
bigj2717's Avatar
I have about the same setup and I'm running stock heat range tr5's and they work perfect
Old May 28, 2010 | 02:20 PM
ss.slp.ls1's Avatar
TR55's will be fine.
Old May 28, 2010 | 02:24 PM
09jyounger's Avatar
NGK TR55s or something similar should be fine. If your heads have been milled to increase compression, I work recommend closing your gap a little bit.....I run .042 in mine and she runs pretty good....
