Sleeper LT1 - best set up?
Old Jun 2, 2010 | 08:38 AM
  #41
merim123's Avatar
OP- You can have someone build you a motor and then have a shop install it? If you're looking for drop off service, why not Lingenfelter? 10k is a lot, but you know what you're getting. Call them up see if what they can do to that package to up the horsepower a bit?
Old Jun 2, 2010 | 08:50 AM
  #42
Roger Mabry's Avatar
Talking Sleeper ? LT1/700R in a 1972 Jaguar sedan
Too bad for you Camaro/Firebird owners, check out the room around the engine bay. Can change plugs from the top and get around the back on the engine easily.
Ported Ram Horn exhaust manifolds, Magnaflow dual exhausts exiting under the IRS with 3:31 gears. Custom K&N cold air kit, , stock dual GM fans, allstock GM AC stuff, TB, EGR delete and no smog stuff at all.
Runs pretty well and is a "sleeper" for sure.
Check out the photos:
http://cid-4437cf12c12b033e.skydrive...3%20LT1%20700R
