Sleeper LT1 - best set up?
Why do this? Because I like the looks of a clean, stock LT1, I like the looks of the LT1 a LOT better than the LS1, my current LT1 is paid for, has low miles and I’ve already done a few non-visible upgrades, and I don’t like the new Camaro (plus we’re talking about $10k versus $30k). Notice that I didn’t mention any numbers (1/4, 0-60) since I’m just thinking about performance close to a current Camaro.
WTF exactly are you trying to accomplish.
You realize there's everything from 15 second ls1's to 7 second ls1's dont you?
Are you asking what will make it beat a stock ls1?
Bolt ons and a tune.
If you're asking anything more than that, the question is so subjective it cant possibly be answered without more info.
Here's the order of progression for most people.
Bolt ons
cam or
cam and heads
power adder
That's it. There's ALWAYS gonna be something faster, but HONESTLY I rarely run across an ls powered vehicle that I cant dispatch fairly easily with my car and it's cam only. Really pisses them off too. Then if I need it I have a bottle on top of that. Usually dont but for some ls cars I do. and some ls cars would still hand me my ***. Just like there are tons of LT cars that would hand me my ***..
Yep, I know it's a fairly broad question. I also know it doesn't take much to get to LS1 performance, but I'm looking for a little better than that. Close to, but doesn't have to beat, LS2 - LS3 power, but again, the key is sleeper status with decent reliability. That's why the Lingenfelter looks like a good deal.
Having said all of that, I just checked and C5 Vettes are running close to $20k in my area, but like I stated, I'd like the idea of a stealth, stock-looking LT1.
OP- FYI: most of that $10k price tag is for the name, u could spend less and get more from some of the engine builders on here
at least check out some of the sponsors and see what they have to say first. The hardest part of this again is keeping it pretty much looking stock. No electric water pump, oversize valve covers, stuff like that.
all stuff that can be done without anyone knowing, no one can make you pop your hood if thats what your worried about it, and wire loom your nitrous
so if you can get that out of the car and have a weight advantage which you will then you should be good to go. the le1 set up is going to get you the closest with out giving it away to much. At least it seems that way on paper. more experienced people could probably chime in.
Either package is a good idea, but I'm partial to the 383 because a properly built 383 will slide the powerband down a few hundred rpm and consequently you wont need to spin the thing to the moon to make power...My hp and tq curves are very flat with lots of area under the curves...
--Alan
Mine has run with 11.20 cars from a roll, and has very little done to it. (stock converter in my car, doesn't launch well)
