Motor out the bottom question
Also, the last thing i did was 6 kmember bolts. get a dolly under there to support the engine and trans. I used a $15 furniture dolly and a 2x12 that was about 5 feet long that I put on top of the dolly and extended it so that it supported the trans too. don't forget the steering knuckle disconnect and removal. It will not slide off when you raise the body up, you don't want that.
and you're going to have crap everywhere if you haven't drained the fluids and even if you did, you'll have all the years of crud on there that will be filthy. I wish I would have done a thorough power wash before I started, it was filthy. so much nicer working with clean parts.
And I would really recommend* getting a roller cart, you do not want to be messing around with a floor jack when you barley have 3" off room to pull the engine out from under the car when its raised in the air. Quick and easy, you pull the car up and roll the goods out.
Here is another picture of once its out. I guess if you do the job outside you have unlimited vertical space but in a garage you are limited and I have a single plane, so its even tighter.
