LT-1 vs LT1 article
Results
LT-1 LT1
HP 353@5,600 351@5,700
TQ 392@4,100 379@3,900
Of course this is engine dyno without accessories, airfilters, etc and using 1 3/4" longtube headers
capper is LT-1 had an electric water pump.... LT1
was using the stocker...
So it looks like GM was telling the truth when they released the LT1 back in 1992 and said the performance was same as 1970 LT1...
Mike
whereas the NEW blood Lt1 has 10.4:1 comp,hydr. roller cam,1.94 1.50 valves and nicely constructed alum heads again for that period in time.
GM has always done a great job in my book thats what has made me a die-hard fan!
Off topic sorta, but got started on a rant and this seemed like a good thread for it....LOL I realize this is LT1, not vortec section, but I've always heard they are a GEN1 copy of the LT1 head, so I figure it's a valid discussion.
I keep hearing about how much better vortec and other later model factory castings are than the old "double hump" heads, but I'm still not buying it despite seeing the flow numbers. For one thing, every time I see flow number comparisons, the old style heads are always 1.94" valved. The only direct A to B dyno test I've seen showed some 1.94" valved double hump heads (camel hump, 300 horse..whatever) on a pump gas, street-strip style 355 compared to stock 96-98 vortec heads....and it did show a 10-15 HP advantage to the vortecs in some areas of the curve. You could argue that this is a fair comparison due to equal valve sizes, BUT I think it's sad that tests like this are used to bash all the old heads as being under-par. I bet the 2.02" versions would have equaled or bettered the later heads. Sure alot of people only have the smaller valved ones, but upgrading isn't that expensive.
)...I had to explian The LT-1 (1970) made 353/391
The LT1 (1996) made 347/379
He mixed up the "-"
the higher cr and bigger cam im sure had something to do with the bigger numbers
