94 lt1 from Caprice
Old May 31, 2010 | 11:38 AM
Fondle's Avatar
Default 94 lt1 from Caprice
what troubles will i run into when putting a 94 lt1 from a police interceptor caprice into a 95 trans am?
also, anyone know i there is a power increase in the police interceptor model engines?
Old May 31, 2010 | 12:48 PM
RamAir95TA's Avatar
The iron-headed Caprice motors made less power and were heavier but can easily be used in an F-platform. What are you trying to do?
Old May 31, 2010 | 02:38 PM
S10Wildside's Avatar
Remove bank 1 knock sensor for motor mount clearance.
Old May 31, 2010 | 03:52 PM
jay7199's Avatar
you need a vented opti, timing cover, timing set, cam with the longer style pin, Flywheel since yours is a 6speed. And that should cover it. The iron heads suck though if its a longblock.
Old May 31, 2010 | 04:21 PM
Fondle's Avatar
Alright jay, should I get the motor?
Also, will the car run with a knock sensor missing? Will it need to be tuned out?
Old May 31, 2010 | 04:32 PM
jay7199's Avatar
no you need the knock sensor, but you can move it. and is it a short block or a longblock? miles and ect.
Old May 31, 2010 | 09:04 PM
96capricemgr's Avatar
The 94 b-body already has the vented opti setup
The police package motor was the same as the other b-body LT1s.
"police interceptor" is FORD terminology.
The shortblock is the same as an f-body got.
Old May 31, 2010 | 09:16 PM
jay7199's Avatar
hmm i didnt know 94 b-bodys had vented optis. Good to know.
Old May 31, 2010 | 10:40 PM
Fondle's Avatar
Has 120k on it, and yes longblock
Old Jun 1, 2010 | 01:47 AM
jay7199's Avatar
hmmm when are you going to look at it?
Old Jun 1, 2010 | 01:50 AM
J-13gtp's Avatar
Id be careful If I was you. I'm not exactly sure what motor size came in the police cars but I know that the b-bodies came in two different flavors. The LT1 and the baby LT1 which is a LT1 that basically has a smaller bore and stroke. I got royally screwed on a setup like this because I didn't do my homework. I wouldn't want you to get burnt on this. So I recommend really looking it over and getting all the details that you can.
Maybe some the guys can shed some light on the differences between the baby LT1 and the regular LT1.
Old Jun 1, 2010 | 02:00 AM
Fondle's Avatar
will do, i few people have already warned me about it possibly being a 4.8, so i will double check
im supposed to check it out tomorrow
Old Jun 1, 2010 | 02:07 AM
J-13gtp's Avatar
Cool. Glad you already know about it. However I would still like to know the difference between the two. I completely abandoned my project after I found out that I got ripped off.
Old Jun 1, 2010 | 02:14 AM
Fondle's Avatar
apparently there is a 4.8 liter version which is doo doo, and then the 5.7 that came in the camaros
the guy tells me his engine has aluminum heads, but i was told most came with iron heads
im not sure how you can tell without running the numbers on the block, or pulling the heads off and measuring the piston size
Old Jun 1, 2010 | 02:39 AM
jay7199's Avatar
is he local? is it the guy who advertises it as "NOT EVEN TALKING BOUT THE ALUMINUM HEADS"
Correct me if im wrong but no B-body had alum heads.
If he is local i can probably come with you and check it out if im awake. Ask him if it would be a problem to take the oil pan off and let us have a look inside. 120k is alot of miles.
Old Jun 1, 2010 | 07:42 AM
shbox's Avatar
You mean 4.3. No B-body came from the factory with aluminum heads. That does not mean someone could not have swapped them. An LT1s will have the numbers 327 cast on all sides of the block.
Old Jun 1, 2010 | 06:29 PM
stevo9389's Avatar
if it does have iron heads you might have plug wire fitment/clearance issues because the plug angles are straight instead of angled. i had iron heads on a temporary motor with old pace setters and MSD wires. had to wrap the primaries so they would stop burning through the spark plug boots.
