Arp head studs
For the threads into the block, you need a sealant, not a lube. Something nice and sticky. The ARP thread sealer has Teflon in it which is a lubricant. Eventually, it'll wash out from the coolant and heating/cooling cycles. Just spin the studs into the block until they stop, don't tighten them in.
Yes, do use the recommended ARP lube on the fine threads on top and torque to they're specs. Don't forget a dab of lube on the nut washers.
For the block threads, go with this:
