cam swap noob ?
Old Jun 2, 2010 | 05:21 PM
1toofastlt1's Avatar
Default cam swap noob ?
Im going to be pulling the engine down to the cam. what seals and gaskets will i need to put it back together?
Old Jun 2, 2010 | 05:38 PM
gregrob's Avatar
Opti drive, front main, water pump drive seals. Front cover, water pump, and intake gaskets, and black RTV or "the right stuff"
If you use "the right stuff" you can forego the water pump gaskets
You'll probably tear the oil pan gasket as well. Most repair it with silicone by loosening up the corners of the pan. Some choose to lift the engine, pull the pan and replace the whole gasket.
You'll need valve seals too, which sometimes cone with your springs.
Old Jun 2, 2010 | 05:44 PM
stryker1320's Avatar
X2 on what gregrob said with the exception that I use RTV copper religiously. Don't ask me why though, its just what I have always used.
Adam $.
Old Jun 2, 2010 | 05:53 PM
is there a gasket kit i can get?
Old Jun 2, 2010 | 07:45 PM
pillarpod's Avatar
here a kit http://www.summitracing.com/parts/SLP-260-1650/
Old Jun 2, 2010 | 07:47 PM
gregrob's Avatar
I think you need to add the opti drive seal to that though. Double check.
Old Jun 2, 2010 | 08:32 PM
spudnick3119's Avatar
That kit is way more than what he needs for a cam swap. Here's mostly everything. I may be forgetting something so make sure...
FEL-MS95580
FEL-TCS45956
Like stated, get a tube or two of either copper or black RTV. I cut my oil pan gasket on one end to free it from the cover and used black RTV to seal everything back up. If you clean everything off real good and lay good beads of RTV, it won't leak.
Old Jun 2, 2010 | 08:41 PM
awesome thanks.
