Lt1 brake bleeding
Old Jun 2, 2010 | 06:45 PM
97 Trans Am ws6's Avatar
Default Lt1 brake bleeding
just finished installing new drilled and slotted rotors all the way around and i ended up going with hawk pads. I bled the brakes like you would normally on most cars and took it for a drive and it seems to be a little stiff, is this normal for these cars? If not am i missing a step?
Old Jun 2, 2010 | 06:56 PM
suicidal racing's Avatar
i believe with these cars because of the abs you have to do it a certian way..not like most cars where your start with the farthest wheel from the master and work your way forward.
Old Jun 3, 2010 | 05:54 AM
Ocala93TA's Avatar
I did mine like that^^^^ when i put my rotors on . I have cross drilled rotors and mine also seems stiff , but i figured once the abs inop light was out the system is bleed and working . i have put about 500 miles on the car and i have no braking issues .
Old Jun 3, 2010 | 08:15 AM
shbox's Avatar
As long as the ABS had not been engaged before you did your bleeding, you can do it the normal way. I have had great results using a vacuum tool (like a MityVac) to do one-man bleeding.
Old Jun 3, 2010 | 09:45 AM
lifeisgood's Avatar
i looked up the mityvac and i couldnt find a dealer for it....i found the vac itself, you have a place youd recommend to buy one?
Old Jun 3, 2010 | 10:17 AM
litch2004's Avatar
Does it make a difference on how to bleed it if you no longer have the abs?
Old Jun 3, 2010 | 11:09 AM
shbox's Avatar
Just about every auto place sells it or something similar (even Sears).
Old Jun 3, 2010 | 01:37 PM
AChotrod's Avatar
I just did mine the regular way and its all good.
lifeisgood's Avatar
gotcha.....many many thanx shbox
Old Jun 3, 2010 | 02:55 PM
I8ASaleen's Avatar
Watch out for the drilled part of the rotor, if it is near the edge of the rotor they are prone to crack all the way out! I know from experience
Old Jun 3, 2010 | 10:33 PM
these are not drilled straight through they are also countersunk at the front and back, so im hoping i dont run into that problem
