Oil pressure
I started using lucas when I had my old 98 WS6 and oil perssure started dropping off and it is still running today it brought my perssure up about 15 psi
Also take your oil filter off, then loosen the big almost 1 inch nut that holds your oil cooler onto your block, I've seen those restricted, blow it out or spray with brake cleaner. But actually if that were restricted it might cause higher oil pressure, I'm not sure at what stage of the oil cycling it travels through the cooler, someone else may be able to verify.
Also, before my engine blew my pressure got low, I switched to 20w 50 it gave me better pressure but not sure if it actually helped anything
