nos plate can only handle a 200 shot but I herd people boring it out for 250
I came across a thead of someone saying they bored there plate from a 200 to handle a 250 shot or something along them lines. The reason im asking is because I have a 200 shot plate and if I can figure out a way for it to handle a 250 then I would definitely do so
thanks
thanks
So the ports in the plate are only .088?
That's the only reason it should quit flowing at a 200 shot.
You will need a -4 line to spray even a 200 shot effectively as well.
If I were you I would just buy the plate from Nitro Daves. I imagine the distribution is much better than that nos plate.
You think itll work cause the plate says
" Nitrous Outlet GM EFI LT1 Plate Conversions "
http://www.nitrousoutlet.com/catalog...=35§ion=51
" stated you could only use a single nozzle discharge or plate with a single nitrous jet no larger than .093 thousands "
So could it handle a 250 ????
Thank you
Thank you
