More problems...
Old Jun 6, 2010 | 07:09 PM
ebeard's Avatar
Default More problems...
Well i have officially messed up the lt1 for the third time... First time i got it all together, i realized the crank threads were jacked, machine shop put in a helicoil. then i nicked a rod journal, got it turned at the shop. So the other night i was setting the rocker preload and using the crank snout bolt to turn the motor over. I started to pull the bolt out afterwards and it got to where it almost wouldn't turn. It ended up pulling out half the helicoil when i got it out....
I really don't want to take it apart again. I don't even know if it's fixable. Can it be drilled out again and have another coil put in? If i took the whole motor to a shop would they be able to fix it with it in the motor?
Old Jun 6, 2010 | 07:12 PM
RamAir95TA's Avatar
For that application, a Timesert would have been a better option. It can be fixed.
And whenever you can help it, you shouldn't use the crank bolt to turn the motor.
Old Jun 6, 2010 | 07:36 PM
ebeard's Avatar
Def. learned my lesson there. What is a timesert?
Old Jun 6, 2010 | 07:37 PM
RamAir95TA's Avatar
http://www.timesert.com/
Old Jun 6, 2010 | 10:12 PM
94fixerTA's Avatar
Those things are bad ***! I put 6 in the sparkplug blowing ford I had and they never blew out again. Helicoil makes one kinda like it too.
Old Jun 8, 2010 | 05:07 PM
ebeard's Avatar
Didn't have to take it apart and the machine shop only charged me $25 to fix it. I'm pretty pumped, and ready for this beast to cruise around and get some noise pollution citations
