Oil inside the intake manifold issue...
Not a blowby issue. Cylinders were 5-5-5-5-4-5-6-5 percentages in loss on the leak down test.
Not coming through the fresh air line from the right side valve cover. I have a filter on it at the valve cover and the hose and the top of the intake is clean.
Not a leaking intake gasket.
This only leaves the PCV valve and the metal line leading to the front of the intake. Upon inspection, I saw oil in this line. Smoking gun found.
I bought this Aluminum oil catch can:
http://www.ws6project.com/user_stor/...0a77b693dfc3dc
This is now installed on the front of the left side head and it is working as intended. It catches small amounts of oil that would normally go down the motors pie hole. I speculate the can might fill up every two oil changes. Also the intake is obviously much much cleaner.
So back to the problem. How does oil get into the PCV valve? I have the shield installed on the bottom of the intake which is supposed to prevent oil from getting it the valve. Is this problem simply normal for the PCV?
